Activity › Forums › Apple Final Cut Pro Legacy › Incorrect Aspect Ratio when rendered
  • Incorrect Aspect Ratio when rendered
    Posted by Evan Schafer on February 14, 2008 at 4:39 pm
    Hey All-
    Im round tripping 3 spots to and from FCP 6.0.1 and Color 1.0.1 When I render transitions or effects back in FCP, the aspect ratio is either stretched or squished for the renders only. The RT preview is correct.
    My original sequence is DV50 16:9. Rendered media from color is ProRes. New sequence in FCP is ProRes 16:9.
    I’m not sure if this is a FCP settings problem or a Color render problem. Any insight?
    Jeremy Garchow replied 18 years, 7 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    February 14, 2008 at 8:37 pm
    Make sure that when the media is back inside of FCP that all of the individual clips have the ‘anamorphic’ flag turned on. Quicktime does a horrible job of writing this flag into movies in a way that FCP and other programs can understand it. You have to hold it’s little hand sometimes. You might have to do this within the timeline itself as well.
    Jeremy
  • Ty Ford
    February 16, 2008 at 2:45 pm
    Hello Jeremy,
    The hand holding to which you refer; what twitch where for individual clips, if you don’t mind.
    Cheers,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Jeremy Garchow
    February 16, 2008 at 5:36 pm
    The other post pretty much explains it. Make sure the anamorphic column is checked in the FCP browser.
    Jeremy
  • Ty Ford
    February 16, 2008 at 9:18 pm
    Thanks Jeremy
    That may be the cause of his problem, but it wasn’t the cause of mine.
    Regards,
    Ty
  • Jeremy Garchow
    February 17, 2008 at 1:01 am
    What is your problem? You never said.
