incorporating HD footage in an SD project
Posted by Doug Kereszturi on January 31, 2011 at 3:50 pmHello all,
Not sure if it possible to incorporate HD footage in an SD project. Can anyone explain the way to do it, if there is a way? I just upgraded to Sony 10.
Also, is there anything I need to know when working with HD footage in Sony? I am making the jump to HD very soon.
Thanks for all of the help.
D
Doug Kereszturi replied 15 years, 7 months ago 3 Members · 5 Replies -
Scott Francis
January 31, 2011 at 4:51 pmMake sure you have the correct project settings for SD and HD should just sit right on the timeline and be fine when editing. If you find you are loosing part of the screen, goto pan/crop tool and select “match output aspect.”
Good luck!
Scott Francis
Mind’s Eye Audio/Video Productions -
Mike Kujbida
January 31, 2011 at 5:08 pmIMO, the biggest advantage of using HD footage in an SD project is the ability to zoom in on something.
For example, I shot a press conference in HD last week and left the camera on a wide shot.
Since this was meant for an SD DVD, I had the ability to zoom in to compensate for the differences in people’s heights (quite a bit in some cases) as well as crop out any unwanted material on the sides.
I plan to do the same thing when I’m shooting a series of interviews soon as they’re all destined for SD.
Lock the camera off on a waist shot and then, in the edit suite, adjust the shot as desired.
This will make my life much easier than zooming in when the interviewee is saying something serious and I need a tighter shot of him/her.
It also allows me to instantly cut from a waist shot to a tight shot or vice versa and not have to worry about anything. -
Scott Francis
January 31, 2011 at 5:14 pmI do that as well, as I use 1080i I keep my zooming in P/C limited to 1280w or 720h so I can still render to 720p and have an HD format as well as SD….works out nice!
Scott Francis
Mike Kujbida
January 31, 2011 at 5:19 pmThe press conference was my very first HD shoot with out new camera (JVC HM700) and the ability to do that definitely made my day.
When I think about it, I’ve been doing it for years with the “pan and scan” feature on oversize stills.
Doing it with video though is a whole ‘nother thrill 🙂 -
Doug Kereszturi
January 31, 2011 at 5:56 pmThanks to all of you. It is greatly appreciated. Can anyone tell me what the settings should be in both SD and HD? I am not sure of these.
Thanks again!!
D
