Activity › Forums › Apple Final Cut Pro › Inability to apply transitions
Posted by John Mendelsohn on September 6, 2011 at 12:16 pmI’ve got Use Available Media checked in preferences. I’m trying both to double-click the desired transition (once having parked my playhead in the desired position), and to drag it onto the break between two clips. I’m getting the little round green + sign, but no transition! What gives?
John Mendelsohn replied 14 years, 12 months ago 4 Members · 6 Replies -
Steve Connor
September 6, 2011 at 1:01 pmIs this on the main storyline or on connected clips?
“My Name is Steve and I’m an FCPX user”
Craig Seeman
September 6, 2011 at 1:06 pmIf you’ve got Use Available Media and you can’t add a transition you may not have the available media. Since you did get the green plus, If you zoom in you may find that it did add the transition at a much shorter duration (too small to see) than the default. Please zoom in and check.
Tom Wolsky
September 6, 2011 at 1:42 pmIf the clips ate connected clips as Steve asked, you need to convert them to a storyline Command-G.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
John Mendelsohn
September 6, 2011 at 1:58 pmVery many thanks to you, sir. That worked. But now I’ve got little B-roll picture-in-picture snips above the main…storyline, and they refuse to accept the dissolve (formerly known, if I’m not mistaken as fade in/fade out) transition. What to do, please?
Tom Wolsky
September 6, 2011 at 5:01 pmSelect the connected clips and press Cmd-G to make them into a storyline. If you just need a fade in or fade out you could also use the Opacity fades. Select the clip and press Control-V for video animations. Double click opacity and drag the fade buttons.
All the best,
Tom
