Activity Forums Adobe After Effects In PREMIERE: Vertical Role Effect/Transition
  • In PREMIERE: Vertical Role Effect/Transition
    Posted by Veronica Orlova on January 7, 2014 at 6:11 pm
    I saw an answer of this question regarding FCP but it doesn’t work for premiere which I use. I really need a very simple transition which doesn’t seem to exit in Premiere or I’m missing something? I need a Vertical Role Effect/Transition. The FCP answer is fairly simple: use the push/slide with an angle at 0. But in Premiere there is no way to set the angle so the transition is always horizontal: push or slide from left to right or reverse while I need from up to down or north to south and reverse. Anybody can help? If it’s a plug-in please let me know where to find it.
    Thank a lot… waiting for your help!
    Veronica Orlova replied 12 years, 8 months ago 48,946 Members · 1 Reply
  • Veronica Orlova
    January 8, 2014 at 1:38 am
    Oh, I’m sorry, I didn’t realize that I posted in After Effect. I dod After effect though and I just saw that ‘Offset’ exist in Premiere under the video effect bin called ‘Distort’. Do you mind explaining to me how to achieve the desired effect?
    Thank you!
