Activity Forums Maxon Cinema 4D In focus Lens effect with glass cube
  • In focus Lens effect with glass cube
    Posted by Malcolm Mowbray on June 22, 2007 at 8:28 am
    Could someone lead me to a way to create a lens effect through a glass cube – so object beyond cube is out of focus but in focus when viewed through glass cube – the lens – so to speak. Thanks for your time and help.
    Adam Trachtenberg replied 19 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 22, 2007 at 5:05 pm
    Technically speaking a cube has no lens effect because the sides are straight. Generally, though, you achieve lens effects by enabling refraction in the transparency channel (increase the Refraction setting over the default value of 1). Glass has a refractive index of approximately 1.5.
