Activity Forums Adobe After Effects In After Effects 7 still no way of importing custom brushes?
  • In After Effects 7 still no way of importing custom brushes?
    Posted by Daniel Haskett on May 29, 2006 at 9:30 pm
    Hi there
    Bascially ive been searching the net to see if its possible to bring in custom photoshop brushes into AE so that you can use them with write on and other uses, but everywhere says its not possible, for 6.5 at least. I just wanted to check if its the same for 7? Also does anyone haev any good alternatives, its just really handy being able to start and end a brush stroke so it animates by itself. Whereas if you do it in an external program the movement has to be done frame by frame right?
    Cheers
    Dan
    Daniel Haskett replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
