Activity › Forums › Maxon Cinema 4D › In a new project – how shall I think about rendersettings and export …
  • In a new project – how shall I think about rendersettings and export …
    Posted by Per Olsson on March 27, 2014 at 10:14 pm
    Hi!
    Im new to Cinema4D and have a question about sizes and export.
    How shall I think when I start a new project. Say maybe final destination I want to export my project in full HD 1920×1080. How shall I start up my project? Do I need to make any preparations in the beginning to be able to view things like they are meant to be in the export?
    I have set the output as HDTV 1080 25. Is there anything else i shall do? Do I need to worry about these things already when I start a project or can I set that in the end.
    For example in a videoeditor I need to match my output when Im doing the edit. Do I need to think in similliar way in Cinema4D?
    thanks
    Adam Trachtenberg replied 12 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 27, 2014 at 11:21 pm
    You have to set the output size and framerate in render settings, which it sounds like you’ve already done, and you also have to set the fps to match in Edit>Project Settings. That’s about it.
