Activity › Forums › Maxon Cinema 4D › In 1 Cinema 4D object, I have 2 animations, and I can only access one….
  • In 1 Cinema 4D object, I have 2 animations, and I can only access one….
    Posted by Jack Skyyler on December 22, 2014 at 4:46 am
    I have a Cinema 4D object of a bear.
    Inside the Cinema 4D file there are two animations:
    (1) Bear Attacking
    (2) Bear Running
    When I drop the object into After Effects CC it works perfectly, I can render it out, but the only animation I can get is the attacking bear. It seems to be the default, and I can’t find any way inside After Effects that will allow me to change it to the running bear.
    How do I change that?
    I’ve taken a screenshot from inside Cinema 4D and you can see:
    Monster Bear 1
    + atk1
    – HyperNURBS
    Monster Bear
    + run
    – HyperNURBS
    Jack Skyyler replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
