Activity Forums Apple Final Cut Pro Legacy IMX 50 speed problems
  • IMX 50 speed problems
    Posted by Pato Kei on January 17, 2008 at 10:33 pm
    Hi everyone
    I am working with IMX 50 footage, everything ok but when I decelerate the speed of the clip, the result is a dirty and unsmooth movement when I play it. Even with Frame Blending enabled. I need help please.
    thanks in advance and excuse my bad english
    Tom Meegan replied 18 years, 8 months ago 2 Members · 1 Reply
  • Tom Meegan
    January 19, 2008 at 3:14 pm
    Try decelerating to a round number like 50% or 25%, if this is appropriate.
    Final Cut Pro does not do a very good job with speed effects, so, if using a round number does not give you the results you need, I would use optical flow in Motion:
    https://forums.creativecow.net/thread/8/962042
    Only works if you are using FCS 2
