Activity Forums VEGAS Pro Improving Sony Vegas Movie Studio Platinum 12 _ Rendering Time
  • Improving Sony Vegas Movie Studio Platinum 12 _ Rendering Time
    Posted by Deleted User on June 22, 2013 at 7:00 pm
    I have approximately 200 videos to render into .mp4 format. The video length can be anywhere between 2 to 8 minutes. The video format for the original source video is .mpg.
    The videos will be used for an instruction purposes and shipped on a DVD You can see more about the end product at the URL: https://www.bagpipe-tutorials.com/bagpipe-tutor.html
    More detail about my hardware configuration and Vegas Settings are can be seen on this document https://www.bdot-inc.com/SVDocument_20130623.pdf
    The problem I am facing is that a 5 minute video is taking me 2 hours to render. There is hardly any difference in rendering speed between CPU and GPU process.
    Could you please check my settings and comment on anything that I could do to speed up the rendering process.
    Any advice will be greatly appreciated.
    Greg
    Deleted User replied 13 years, 2 months ago 3 Members · 6 Replies
  • Deleted User
    June 23, 2013 at 8:34 am
    I found a thread on Sony Vegas forum which suggested that you reduce the Dynamic Ram setting to a lower value. They used 375 MB, I tried it and lowered it to 250 MB. 2 Video that was previously taking 2 hours plus, now takes 2 to 3 minutes. Previously I was using 7 000 MB for the Dynamic Ram setting.
    This is coupled with using CPU for rendering and not GPU. GPU rendering value is set to “Off”.
    Greg Barnes
    Auckland. New Zealand
    http://www.bagpipe-tutorials.com
  • John Rofrano
    June 23, 2013 at 3:14 pm
    [Greg Barnes] “Could you please check my settings and comment on anything that I could do to speed up the rendering process.”
    You didn’t post your project settings or the media settings so we can see if they match your render settings. These will have an affect on render times.
    I did noticed that your render is an odd 512×282 so I’m guessing that your CPU is having to resize each and every frame and this probably contributing to why it’s taking so much time.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Osbun
    June 24, 2013 at 7:08 pm
    The AMD processor is far from the best CPU for video rendering, but what John Rofrano said about your source footage ratio being changed in it’s final render output is 1000% the reason why you’re getting the horribly long render times. I tried a few render tests when I built my new system this past December, and one of the tests I did was down-converting my 1080p data. This increased my render times significantly.
    Why such a small video size for a DVD?
    Dave
  • Deleted User
    June 25, 2013 at 5:35 am
    Thanks guys for the replies.
    The small video size is because I have to fit approximately 80 videos onto a dvd and 100 or so audio clips. Both the audio and video clips are linked to a PDF tutorial document of about 80 pages.
    I will update the media settings onto this PDF document after this post.
    Greg Barnes
  • John Rofrano
    June 25, 2013 at 10:18 am
    Oh, so the DVD is just the media that you deliver it on but the project is not a playable DVD. I get it.
    ~jr
  • Deleted User
    June 25, 2013 at 5:35 pm
    Yes that is is correct John
    Greg Barnes
