Activity Forums Adobe Premiere Pro Improving real-time playback
  • Improving real-time playback
    Posted by Oded Erell on April 23, 2009 at 6:40 pm
    Hello all,
    Please forgive me if I ask an ignorant question or make stupid assumptions, (I’m new to HD editing)
    I’m working on an animation project that I’m currently editing on Premiere Pro 2 at 1920×1080 24p with 8bit RGB Tiff sequences.
    My machine:
    Win XP Pro 32bit
    Intel DX38BT board
    Core 2 Quad QX9650 3Ghz
    4GB DDR3 RAM
    nVidia Quadro FX 1700
    (It’s really a 3d animation machine)
    I used to render every edited sequence into a compressed AVI to get decent playback of the edit and the transitions,
    But since the project is getting bigger and bigger,
    I decided it was time to get better storage that will have enough capacity for the whole movie, be safe, and be fast enough for real-time playback without needing to render every edit to compressed AVI.
    So I did some reading, and got a Rack mount Infortrend Eonstor with a 12 SATA drive Array connected through PCI-e x8 SAS, configured as RAID 5+hotspare.
    The reason I bought such storage without adding or assembling a workstation with an editing card, is that as an animator I never really needed to do much capturing,
    And I thought I may get along with just premiere editing in desktop mode relying on the storage speed for performance.
    Using the RAID there is a significant playback improvement,
    Premiere now plays the sequences quite smoothly (if not real-time) apart from the occasional “burp” especially during transitions (mainly cross dissolves).
    The thing is I think the storage is capable for much more than that.
    I did tests using the AJA System test Utility,
    For uncompressed HD and 2k formats and the results vary between around 450MBps to around 700MBps.
    My Questions are:
    Do editing cards like AJA XENA, or BMD Decklink improve video playback and transitions?
    Or do they just provide IO connectivity and enhanced video file support?
    What is the relation between CPU, GPU, Editing card, and storage, in providing good playback in Premiere Pro?
    Do I need an Editing card, or Invest in a more powerful GPU?
    Do I need to get a server board and two Xeons?
    (right now premiere is using about 15 to 20 percent of the 4 cores in the machine)
    Thanks in advance for any tip, or info on the subject,
    Oded
    Oded Erell replied 17 years, 4 months ago 3 Members · 3 Replies
  • Vince Becquiot
    April 24, 2009 at 4:50 pm
    The AJA card will improve your playback but you have to work in an AJA project. They are also very picky about which slot and what other hardware you use with them, so plan your system setup according to the AJA website. In fact they only recommend a handful of motherboards. The BM is also a cheaper alternative but again, you need to work in a BM project.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Arc Nevada
    April 25, 2009 at 7:44 pm
    I think you would be better off investing in PP CS4. PP CS4 should make good use of the Quad Core system. You can also out put to an NTSC monitor using the graphics card’s HDMI or S-Video port. You can also loop through the camera or DV converter.
  • Oded Erell
    April 26, 2009 at 9:15 pm
    Thanks for the tips guys,
    I’m very curious about Premiere Pro CS4 performance,
    I have some more questions about the XENA,
    I’ll ask them in the XENA forum.
    Oded
