Activity › Forums › Apple Final Cut Pro Legacy › Improve already captured files/sequences in FCP S2
Posted by Audiovideo on May 29, 2007 at 1:00 pmThere have been lots and lots of great ideas, observations, and suggestions on this forum about FCP Studio 2–especially on “what to do” to take advantage of all the features in Studio 2 when capturing, editing, color correctiong, etc. But I’d be interested to know how you can take advantage of FCP S2’s power to improve “already” captured files…and/or already made clips/sequences. For example…if one has already filmed and “captured” i.e., DVX100A camera @ 24p > captured NTSC DV via firewire > to a 29.97 timeline…how could you improve the quality of your sequence file ( i.e., resolution, depth of color, detail, etc.) in order to end up, eventually, with a higher quality DVD? Thanks!
Audiovideo replied 19 years, 3 months ago 5 Members · 17 Replies -
Shane Ross
May 29, 2007 at 1:45 pmCapturing DV via firewire as DV/NTSC (or DV/PAL) is the best quality you can get. You can convert to DV50 or uncompressed 8-bit for color correcting to reduce the compression artifacts, but I doubt you’d notice a difference if you did that over just color correcting regular DV…after you compress for DVD.
Shane
Littlefrog Post
http://www.lfhd.net -
Mark Maness
May 29, 2007 at 1:53 pmI agree with Shane…
Your thinking is great…. BUT you really can’t improve DV. DV is DV, no matter what you do with it. You CAN reduce some of the artifacting like Shane said, but quality is based on your input quality. If you capture DV using the component outputs of your machine, it will still look like DV because of the compression of DV.
You only option to gain quality is to sell your DV equipment and replace it with HDV. Downconverted HDV is really impressive when it goes to DVD.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Audiovideo
May 29, 2007 at 3:30 pm[Wayne Carey] “If you capture DV using the component outputs of your machine, it will still look like DV because of the compression of DV.”
Bummer! Hmmm…what if I re-capture from the camera using ProRes 422? Any benefit? Or is there another way to extract the video from the camera to avoid its 5:1 compression? Can you tell I’m desperate, here? 🙂
Mark Maness
May 29, 2007 at 3:36 pm[audiovideo] “Bummer! Hmmm…what if I re-capture from the camera using ProRes 422? Any benefit? Or is there another way to extract the video from the camera to avoid its 5:1 compression? Can you tell I’m desperate, here? :-)”
The only way you can benefit from this is to capture on the fly and avoid going to tape. Once it is on tape, it’s compressed. Now, everybody here has their own opinion on this but I do have to agree that DVD is DV no matter what you do with it. DVD has the same compression scheme as DV video, so it all depends on what you wish to do with it.
This project of yours… is it going to DVD only? If so, don’t worry about it. If you have lots of graphics that need to be keyed, then I would suggest that you capture all of your footage using another better quality codec. DV doesn’t handle keyed graphics very well.
Wayne Carey
Schazam Productions
Shane Ross
May 29, 2007 at 3:41 pm[audiovideo] “what if I re-capture from the camera using ProRes 422? Any benefit?”
Only if you color correct and add filters. Rendering compressed the footage less than regular DV does.
[audiovideo] “Or is there another way to extract the video from the camera to avoid its 5:1 compression?”
Can’t avoid this. Once recorded onto tape, the 5:1 compression is there…permanently. The only way to avoid it is to not record to tape, but capture directly into FCP. But carrying a computer and hard drive attached to a camera isn’t very convenient.
Shane
Littlefrog Post
David Roth weiss
May 29, 2007 at 3:44 pm[audiovideo] “is there another way to extract the video from the camera to avoid its 5:1 compression?”
Only if you capture directly to hard drive when shooting, thereby avoiding the compression stage all cameras require before recording to tape.
Just for the record, DV is not inherently ugly. In fact, DV can look very good. Of course, it can look very bad too, but then so can HD — it all depends on how its shot. If your lighting is such that the video looks really bad, nothing can really help. You can try to spruce it up with color correction, but you’ll never be able to turn a sow’s ear into a silk purse after its shot.
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Audiovideo
May 29, 2007 at 4:08 pmThank you both so much! I truly appreciate your knowledge and willingness to help! To answer your question, I am going to DVD only (thank heavens!) It’s just that I have so much invested into this project that I need to get the best results possible. The footage was shot in good light (generally speaking, that is) and white balanced as well as possible. Focus, composition, etc. was done fairly well. Any suggestion as far as what settings to use in Compressor in FCP S2? (BTW…if you’re looking for a DVX100A to buy…BOY(!) do I have such deal for you!!!)
Mark Maness
May 29, 2007 at 6:51 pm[audiovideo] “Any suggestion as far as what settings to use in Compressor in FCP S2?”
The highest quality you can fit on your DVD is the best setting. I’ve never had any issues using the 90 min setting for doing DVDs of broadcast programs.
Wayne Carey
Schazam Productions
Rafael Amador
May 30, 2007 at 3:15 amI’m sorry but I do not agree with Shane and Wayne. Yes, once is in your tape you can not get nothing better than that you will get through the Firewire. But in your time-line you can improve a lot the look of that footage. If you make to your DV footage a Chroma resampling (i.e. Nattress Chroma Sharpen) and CC, you do not get the same result in a DV time-line than in a 8b Unc one. Just make a test with a clip where somebody wears a red T-shirt.
Also you can get a better MPG2 than the one of “”90 minutes” of Compressor. Just short the GOPs and set the OPEN. You will see the difference.
Cheers,
rafael
