Activity › Forums › Apple Final Cut Pro Legacy › impossible to arrange correctly the clips in the browser
Posted by Alvaro Lanciai on January 7, 2009 at 5:06 pmHi to everybody….
when I work with clips after capture, I want to set the browser view setting as “VIEW AS MEDIUM ICONS” and after “ARRANGE BY NAME”….in this way the clips should be positioned from CLIP-1 to CLIP-180 for example…but it is not so simple, infact I always find CLIP-1, CLIP-10, CLIP-100, CLIP-101, CLIP-102…. CLIP-109, CLIP-11, CLIP-110, CLIP-111, CLIP 112……119, 12, 120, 121….How could I solve this madness ?
moving manually the clips couldn’t be the right solution….I hopeThank you for your attention
Alvaro Lanciai
Drew Hudgins replied 17 years, 1 month ago 7 Members · 15 Replies -
Steven Gonzales
January 7, 2009 at 5:45 pmHere’s how I would fix that (there may be an easier way):
Export batch list from the bin with clips you want to rename.
Open that batch list in Excel.
Insert two new column next to the name column (if name is column A, then the new empty columns are column B and C).
I assume that you have no more than 999 clips named “clip-NNN”.
Put this formula in cell B2 — “=LEFT(A2, 5) & REPT(0, 8-LEN(A2)) & RIGHT(A2, LEN(A2)-5)”
This takes the left 5 characters of A2, then repeats zero for the correct number of places, then adds the clips number back in, all through formulas and text concatenation.
Copy and paste that forumla all the way down column B. Then copy column B, paste special to column C, with “paste values”. Add the correct column name (“Name”) back in Column C to match the column name in Column A.
Now delete columns A and B, save, and export as tab delimited text.
Import this as a batch list to Final Cut.
Reconnect to the new clip names.
David Roth weiss
January 7, 2009 at 5:54 pmIf your clips happen to have timecode, you might try sorting using the “Media Start” column, which would, of course, order your shots from the earliest timecode to the latest timecode, thus also ordering your clips names exactly as you would like.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Alvaro Lanciai
January 7, 2009 at 6:03 pmdear David,
thank you for your answer, I know that viewing browser “as list” i can order the clips as I wants…but in the “view as medium icons” mode ?
Alvaro
MAC INTEL dual quadcore 3ghz
8gb ram
macos 10.5.5
fcp 6.0.4 -
Alvaro Lanciai
January 7, 2009 at 6:05 pmdear Steven,
thank for your answer, if I don’t find anything faster and easier I’ll try soon….Alvaro
8gb ram
macos 10.5.5
fcp 6.0.4 -
Chad Cooper
January 7, 2009 at 6:21 pmAre you aware that you can turn on a thumbnail column in list mode? That will allow you to arrange them by any column heading while still seeing the thumbnail. Just rt+click the column headings at the top of the browser and select show thumbnail.
Not your ideal solution but it might work for you.
Chad
John Fishback
January 7, 2009 at 6:57 pmWhen log & capturing or log & transferring I name my clips with zeros in front depending on how large the greatest scene number is. Then it works as you wish. You can do that after the fact, too.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Alvaro Lanciai
January 8, 2009 at 8:03 amthankyou Chad,
I already know… this could be an alternative way to solve my prob, but I prefer to work “as medium icon” just to work in a more “friendly” space with my clips…..
thnk
Alvaro
Alvaro Lanciai
January 8, 2009 at 8:10 amdear John, thank you for your answer,
could you explain me your solution with an example…?
From your answer I understand that you rename clips with “zero” that are not in the right order…?
Am I right…?thank you!
Alvaro
8gb ram
macos 10.5.6
fcp 6.0.5 -
John Fishback
January 8, 2009 at 5:00 pmLet’s say your highest clip is Sc210. Then when entering lower numbered scenes they’d be Sc005, Sc076, etc. When you enter the leading zeros, all the clips will be ordered in numerical order.
Be sure to name all the clips exactly the same, Sc210 will be treated differently than Sc 210.
If you’re interested in a technical explanation you can read https://en.wikipedia.org/wiki/Collation.
John
Alvaro Lanciai
January 8, 2009 at 5:09 pmthank you john,
but I can apply this system only writing clip after clip after capturing…isn’t it?Alvaro
8gb ram
macos 10.5.6
fcp 6.0.5
