Activity Forums Apple Final Cut Pro importing xdcam files
  • Michael Sanders
    January 23, 2012 at 6:27 pm
    It depends if you want to use the date added metadata. If your not bothered do this:
    1 Create an event in FCP X.
    2 Quit FCP X
    3 Open XDcam browser.
    4 Go into the pref menu, click the FCP tab and select the original media folder of the event you created as the destination.
    5 In the explorer window select the clips on the disc and then (under Version 2) go clip – import to FCP.
    Version 1.xx its called “Register for Final cut” and is in the file menu
    6 When its done open FCP X and the material should be in there.
    If you do want to use the data added metadata
    In step 4, select a temporary data location.
    Then step 6B) import material into the event.
    Michael Sanders
    London Based DP/Editor
  • Lance Bachelder
    January 23, 2012 at 6:42 pm
    Also make sure you’ve done the Pro Apps update which lets FCPX see all the various XDCAM flavors.
    Lance Bachelder
    Writer, Editor, Director
    Irvine, California
  • Mark Dobson
    January 23, 2012 at 8:12 pm
    Any idea if this works under Lion.
    Looked on the site and could only see Snow Leopard.
    Also am I right in thinking this is the route to get Canon MXF files into FCPX?
  • Ian Bailey
    January 23, 2012 at 9:20 pm
    The latest version of Sony’s XDCAM Transfer works under Lion. I use it to MOV the footage from the cards and then open the files in FCPX.
    Not sure about Canon MXF… give it a try!
  • Mark Dobson
    January 24, 2012 at 6:17 am
    Thanks for that Ian.
    Once I remember my Sony log in I’ll give it try and report back for the edification all those about to pick up a C300.
  • Peter Christensen
    January 24, 2012 at 4:22 pm
    thank you very much for your suggestions, they worked!
    also found this info regarding xd cam importing issues… maybe it is of some help to others.
    https://support.apple.comkb/HT4724?viewlocale=en_US
