Activity › Forums › VEGAS Pro › Importing transparent media doesn’t go away in SonyVegasPro
  • Francois Pénzes
    May 2, 2019 at 1:01 pm
    Hi Johnson
    Can you upload the file ? I’ll take a look at it and see if I can reproduce your problem.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Danny Hays
    May 2, 2019 at 11:39 pm
    Try right clicking on the event on the timeline, properties, media tab, set alpha channel to premultiplied. This has worked for me before.
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
  • Francois Pénzes
    May 3, 2019 at 11:10 am
    It helps if you are using the right type of file. .PNG will do the trick.
    It also helps if your .PNG has been created from the onset with the transparency.
    But definitely, .JPGs won’t work.
    Cheers !
