Activity Forums DaVinci Resolve importing titels and video mix downs from avid
  • importing titels and video mix downs from avid
    Posted by Martin Halm on January 13, 2013 at 9:24 am
    i have an avid MC 6 project using only AMA files (canon 5d)and some titels and background clips made in avid (DNxHD 185)
    importing the AAF in resolve works fine – i gave the original files a tape name in avid and the same as reel name in resolve – so it finds the corresponding files.
    but there are some FX clips (video mixdown to DNxHD), titles and simple background clips (like fade to white) how can i link to these in resolve, so i have a complete final timeline to grade?
    thanks – martin
    iMac 2.93 GHz Intel Core Duo
    Resolve Lite 9.03
    Avid MC 6
    Martin Halm replied 13 years, 7 months ago 3 Members · 3 Replies
  • Bouke Vahl
    January 13, 2013 at 9:47 am
    You don’t
    Normally before going to CC you strip all effects.
    Makes sense, if you have a fade to white on a clip that needs tons of cc, you won’t end up with white…
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Pat Horridge
    January 14, 2013 at 9:45 am
    If you need to pass a videomixdown or similar. Then in Avid export it as a file and either re-import or AMA it.
    But as said the grade should be Raw elements not titles or effects.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Martin Halm
    January 15, 2013 at 1:30 pm
    thanks bouke and pat,
    you are so write – does not make sense, what i intended to do.
    but i like the tip to mixdown, export, reimport for AMA link.
    cheers – martin
    Resolve Lite 9.03
    Avid MC 6
