Activity › Forums › Maxon Cinema 4D › Importing then Extruding a Text Spline from Illustrator
  • Brian Jones
    March 12, 2010 at 11:25 pm
    There should be something visible after you drop the spline in the ExtrudeNurb – it might not be right depending whether splines are closed etc.
    …unless your logo came in as a bunch of separate splines or a bunch of splines in a null, then you would have to check off Hierarchical in the Extrude’s settings to get them to show.
  • Keith Hill
    March 12, 2010 at 11:37 pm
    That was it. Thanks a lot Brian!
    The Hierarchical box was unchecked/.
    Keith Hill
    http://www.UptownJazzDallas.com
    https://www.LightedPath.biz
    http://www.TheJudahSet.com
    Dallas, TX
    G5 2Ghz, OS X (v10.4.11), Final Cut Studio 2 | Combustion 2008 | Cinema4D | Mocha | DVX100A 24p
