Activity › Forums › Adobe After Effects › importing swf files in After Effects?
  • importing swf files in After Effects?
    Posted by Rafael on January 28, 2006 at 9:21 pm
    Is there any way to import a flash movie into After Effects in the swf format?
    You may wonder who the hell would enjoy animating in Flash rather than in After Effects…
    The reason is that I am using a software named Moho and it can export as quicktime or as swf files. Which I would like to use so I could keep vector quality and zoom capabilities.
    Ramana Prasad replied 17 years, 3 months ago 4 Members · 3 Replies
  • Andrew Kramer
    January 28, 2006 at 10:07 pm
    negative
  • Filip Vandueren
    January 29, 2006 at 10:34 pm
    Export it as a Quicktime (if there is no scripting to drive the animation),
    you can use a higher resolution perhaps so you can still do some scaling.
    Or do a frame by frame export still to illustratoer (yikes !), Maybe someone wrote a script or a plugin that can do that ? Well, I certainly hope someone did.
    That way you can create a illustrator sequence, but I think not all flash effects and features will export perfectly.
    Haven’t tested it though.
  • Ramana Prasad
    June 12, 2009 at 8:14 am
    When i importing the swf move in After Effects 6.5,After Effects Error: retrieving move from file “wheel.swf” — no quick time move found(-2048),(10 :: 21 ) was coming what is problem. please help me.
