Activity › Forums › Adobe Premiere Pro › importing subtitle XML doesn’t generate a timeline
  • importing subtitle XML doesn’t generate a timeline
    Posted by Matt Brodie on June 5, 2015 at 6:05 pm
    Greetings all,
    I’m trying to add subtitles to a project I just finished. The subtitle company has provided a set of PNGs and an XML file. I have a lot of experience importing XMLs from DaVinci Resolve round trips, so I expected to drag and drop the xml into premiere, it would generate a timeline and then ask me to relink the PNG files and all would be well. It asks me where the PNGs are as expected, but then I end up with a bin full of PNGs and no timeline. Looking at the text in the XML I see it has timecode information etc.
    Is there a header here that I can add or an xml converter I need or something?
    Any help is appreciated.
    Bouke Vahl replied 11 years, 3 months ago 2 Members · 1 Reply
  • Bouke Vahl
    June 11, 2015 at 8:44 am
    Hi Matt,
    AFAIK, a XML for Premiere is for an entire project, not just a sequence.
    You say you don’t get a sequence?
    My trick is to use an old fashioned EDL, with clip names (named after the png’s).
    That also requires re-linking, but it works.
    Perhaps your translator can give you an EDL?
    (I can send you an example if you like, mail me direct if you need one.)
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
