Activity Forums Boris FX Importing square pixel image in Avid MC 3/ Boris Red 4.2
  • Importing square pixel image in Avid MC 3/ Boris Red 4.2
    Posted by Steve Mott on September 30, 2009 at 3:03 pm
    When I import a photoshop file(720×486) into Boris Red ver4.2 plug-in within Avid Media Composer (16×9 project) as square pixels, Boris lists the file’s native size as 720×486, but the import size lists 800×486. Why does Boris change the size to this? Is there an import setting to stop Boris from doing this?
    Matt Mullen replied 16 years, 11 months ago 3 Members · 5 Replies
  • Matt Mullen
    September 30, 2009 at 4:20 pm
    Steve,
    What is the original size of the image before import?
  • Steve Mott
    September 30, 2009 at 6:14 pm
    720 x 486 pixels
  • Matt Mullen
    September 30, 2009 at 7:35 pm
    Steve,
    It should be retaining the original size of the image…can you send it to me to test with?
    mattm@borisfx.com
  • Peter Mcauley
    October 1, 2009 at 2:55 pm
    Hi Steve,
    I’m assuming that you are importing the file directly into the RED / AvidFX and not pulling the image from the Avid timeline … is this correct? If so, then I suggest that you click on the face of the track that contains the image and in the Control Panel set the Aspect pop-up to “Use Project Aspect Ratio”.
    Please let us know if this solves the problem.
    Peter.
  • Matt Mullen
    October 5, 2009 at 6:17 pm
    Steve,
    Haven’t heard from you. Any luck with this?
