Activity Forums Adobe Premiere Pro Importing sony F65 footage into Premiere Pro CS6
  • Importing sony F65 footage into Premiere Pro CS6
    Posted by Adam Anton on August 27, 2012 at 11:58 am
    Hi, I’m trying to import F65 SR footage into Adobe Premiere Pro CS6 and Premiere doesn’t seem to take the native .mxf files. Apparently there’s a plug in but I haven’t been able to find it. Has anyone gone through this process and know the plugin I need? It would be a massive help!
    I’m using a MacPro 12 Core Xeon with 12gb of ram OSX 10.7.3
    William Kamp replied 13 years, 9 months ago 2 Members · 1 Reply
  • William Kamp
    November 15, 2012 at 2:58 am
    Yup, there is now a plug-in for that. Download it here:
    https://www.sonycreativesoftware.com/plad-rw1
    Then make sure to put it into a common area that all adobe applications can read it by doing the following:
    Find the Premiere Pro CS6 application in your Applications folder then right-click on it and choose “Show Package Contents”. Then navigate inside the application to “Contents/Plug-Ins/Common/” and move the ImporterF65RAW.bundle file into to “/Library/Application Support/Adobe/Common/Plug-ins/CS6/MediaCore/” (this is the Library folder at the root of your boot drive, this is NOT the Library folder located in your user Home folder)
    In other words move
    /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterF65RAW.bundle
    to
    /Library/Application Support/Adobe/Common/Plug-ins/CS6/MediaCore/ImporterF65RAW.bundle
