Importing slow motion (50fps) footage from PDW-F800 XDCAM HD422
Hi There,
For our exam film project at the dutch film school we used the Sony PDW-F800 XDCAM HD422 camera in 50MB/s mode. Some footage was shot in 50FPS to attain a slow-motion effect. Now the camera automatically reduces the resolution by half for 50 FPS so the material is actually in 1920×540 instead of 1920×1080.
Here is the first problem: AVID 5 will not import the clips. To solve this issue we use XDCAM Transfer to import the video to .mov and then Compressor to convert it to Prores 422HQ. That works fine for most clips, though it is a bit time consuming, so if anyone has a better way to get the material into AVID, please let me know.
The second problem is a bit tricky. XDCAM Transfer somehow upscales the image to 1080p, which looks great, but there is one shot, where there is a group of people moving horizontally through the frame in slow motion. Somehow all vertical edges seem to double and jitter in the movement. Now I know that edge doubling can occur if horizontal movement is too fast, but that does not seem to be the case here. The jitter is so bad we suspect there is some other problem. Does anyone have tips what we could try to do about this?
Kind Regards,
Titus
Nachbrenner Productions
Amsterdam/Zaandam
http://www.nachbrenner.com
