Activity Forums Adobe After Effects Importing RAW sequence into AE CS3???
  • Importing RAW sequence into AE CS3???
    Posted by Chad Cottrell on January 3, 2010 at 9:07 pm
    Hello:
    I’ve been searching the posts, and haven’t quite found the answers I need.
    I’m trying to import an RAW image sequence into AE CS3. I was trying to replicate the steps from a tutorial about using Bridge & ACR to import TIFF or JPEG sequences, but it’s just not working with RAW.
    AE says that it can’t “parse the file”. I have the newest ACR (5.6) update for Photoshop, but I have no idea whether I need something similar for AfterEffects?
    Can someone please advise?
    Thanks so much!
    Chad Cottrell replied 16 years, 8 months ago 2 Members · 3 Replies
  • Todd Kopriva
    January 3, 2010 at 10:04 pm
    According to this document, version 5.6 of the Camera Raw plug-in might not be compatible with After Effects CS3:
    https://kb2.adobe.com/cps/408/kb408941.html
    I’m not 100% certain of this, but you may need to use the older version of the Camera Raw plug-in if you’re still using AFter Effects CS3.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Chad Cottrell
    January 3, 2010 at 10:57 pm
    Thanks.
    But I have no idea where the camera raw plug even lives, in the AE folder. I don’t immediately see anything like that in the “format” folder in the “plugin” folder. So, with either version of the ACR plug, would I need to add that to the AE folder?
    Cheers.
  • Chad Cottrell
    January 4, 2010 at 9:01 pm
    Anyone else have experience with this? Seems like it must be a common issue with so many cameras shooting in RAW, these days.
