Activity › Forums › Apple Final Cut Pro › Importing PSD Files Into FCPX
  • Importing PSD Files Into FCPX
    Posted by Adam Markon on May 2, 2013 at 12:57 am
    I’m a novice with Final Cut Pro X, but I’ve used FCP 7 extensively, so I know that the process of importing .psd files into FCP used to work relatively seamlessly. However, today I was working on a Photoshop file in which I need to animate some text and superimpose it over a video.
    I have about 50 text layers, all of them rasterized, and several images, all of which have had their layer styles flattened. I export the .psd file using the Maximize Compatibility option, and when I preview the file on the desktop using Quick Look it displays correctly. However, when I go into FCPX and import the .psd file and put it on the timeline it shows up as completely black.
    I have the viewer background set to checkerboard in preferences, and the problem is only when I play back the video. If I scrub over an individual layer it appears as transparent. I’ve tried placing the .psd file in by itself, I’ve tried placing it over a solid white background, yet it always shows up the same.
    Any help would be appreciated, I’m pretty lost here.
    Adam Markon replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
