Activity Forums Adobe After Effects Importing PSD back into After Effects, not staying at original dimensions?
  • Importing PSD back into After Effects, not staying at original dimensions?
    Posted by Ivan Pk on November 23, 2013 at 1:03 am
    I had a tried and true process that I’d do to render a still from after effects as a PSD, edit it in photoshop, then re-import it into After Effects and it would be perfectly aligned with the frame I’d been working on. I used the shortcut opt-cmd-s to generate the freeze-frame PSD.
    Now when I import the PSD back into after effects, it’s much smaller then the source file and is about 50% the size and in the middle of the window. Resizing the document to fill the window is a pain and not always as accurate.
    Am I doing something wrong? Is there a simple fix to have the PSD fill the screen again?
    Thank you!
    Sean Lloyd replied 12 years, 5 months ago 4 Members · 4 Replies
  • Erik Waluska
    November 24, 2013 at 7:31 pm
    My guess is that you had the resolution of the comp set to less than 100% when you exported the frame. Still frames, unlike video, are exported at the resolution set in the comp. BTW, you can export a layered PSD file from AE, just go to Composition>Save frame as>Photoshop Layers. Some things won’t translate to Photoshop but reasonably simple comps will usually come through OK.
    Erik Waluska
    EAWmedia
  • Todd Kopriva
    November 28, 2013 at 5:56 am
    Be sure to submit a bug report if something is working incorrectly:
    https://adobe.ly/ReportBug
    After Effects team blog
  • Sean Lloyd
    March 27, 2014 at 6:16 am
    Don’t know if this will get monitored or not, but I am having the same problem and I tried what was suggested here and it didn’t work for me. So I figured, oh well and just tried to resize it, but the resolution is not the same and so the still seems very blurry, compared with the original footage. I used PNG to try to maintain the same quality, but it didn’t work. I have had this problem before and found a work-around, but it is an important function for what I have been working on lately, so if someone has any idea, I would be very grateful, as I have searched around a fair amount and can’t seem to find anything. Thanks…
  • Sean Lloyd
    March 27, 2014 at 6:33 am
    For anyone else who may encounter this… It’s a stupidly simple fix. It appears that the default setting on the OUTPUT MODULE SETTING are set at 480×720, so I just hit resize to change it to my Comp Setting, (which for me was 1920×1080) and it worked fine. Don’t know why it doesn’t follow the comp size, but…
    PS I am on CS6
    Cheers…
