Activity Forums Zaxwerks importing (prepareing) illustrator CS2 files into Invig
  • importing (prepareing) illustrator CS2 files into Invig
    Posted by Matt Stoltz on June 23, 2005 at 11:15 pm
    hey all I have a logo that i made paths around in ill so i could use invig on it –well i know you have to save ill files as ill 8 for invig but do u save as ai or eps –cause all i get in invig is an error saying –sorry no vector paths found
    I was also thinking there is something i have to change in my ill prefs??
    any help
    matt
    Matt Stoltz replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    June 24, 2005 at 12:26 am
    Hi Matt,
    You didn’t say which version of Invigorator you’re using, which would determine whether you have to save as an older version of Illustrator. In any case, save your file as Illustrator format rather than eps. Use only filled closed paths for best results. Convert text to outlines as well. Avoid gradient fills or any bit-mapped placed images.
    Does this help?
    Jon
  • Matt Stoltz
    June 24, 2005 at 3:27 am
    i have invig 4 –i figured it out –yeah thanks for posting you answered it –I didnt have my path filled so invig didnt see it
    thanks jon
    matt
