Activity Forums Apple Final Cut Pro Legacy Importing Photoshop File With Text Into FCP X Shows Up As Black
  • Importing Photoshop File With Text Into FCP X Shows Up As Black
    Posted by Adam Markon on April 26, 2013 at 12:19 am
    I’m a novice with Final Cut Pro X, but I’ve used FCP 7 extensively, so I know that the process of importing .psd files into FCP used to work relatively seamlessly. However, today I was working on a Photoshop file in which I need to animate some text and superimpose it over a video.
    I have about 50 text layers, all of them rasterized, and several images, all of which have had their layer styles flattened. I export the .psd file using the Maximize Compatibility option, and when I preview the file on the desktop using Quick Look it displays correctly. However, when I go into FCPX and import the .psd file and put it on the timeline it shows up as completely black.
    I have the viewer background set to checkerboard in preferences, and the problem is only when I play back the video. If I scrub over an individual layer it appears as transparent. I’ve tried placing the .psd file in by itself, I’ve tried placing it over a solid white background, yet it always shows up the same.
    Any help would be appreciated, I’m pretty lost here.
    Neil Patience replied 13 years, 4 months ago 2 Members · 1 Reply
  • Neil Patience
    April 26, 2013 at 6:39 am
    Hi Adam
    You will likely get more responses if you post in the FCP Techniques forum here
    https://forums.creativecow.net/fcpxtechnique
    This is FCP Legacy – you may get an answer here but more likely over there.
    cheers
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
