Activity Forums Apple Final Cut Pro Legacy importing .pct files
  • importing .pct files
    Posted by Jason Noto on February 28, 2007 at 11:16 pm
    I am trying to import a .pct image file into FCP 5.02 (and then invert the Alpha channel), but Final Cut does not recognize the file and will not import it.
    Does anyone know how I can get FCP to understand the .pct file format, or convert the .pct file (perhaps using Graphic Converter software) and import the Alpha channel?
    Thanks. I appreciate any insight and info you are able to share
    Jason
    John Pale replied 19 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    February 28, 2007 at 11:28 pm
    Why not convert the file to a 32-bit Targa file in PhotoShop?
  • John Pale
    February 28, 2007 at 11:35 pm
    tell us more about the file.
    FCP should not have trouble importing a PICT file…
    Is there anything unusual about it that you have neglected to tell us? Is it Grayscale instead of RGB, for instance?
  • Bret Williams
    March 1, 2007 at 7:36 am
    Pict is pretty much the format I always use out of habit. Works fine. Maybe it’s not really a pict.
  • Shane Ross
    March 1, 2007 at 7:37 am
    If it was created on a PC there will be issues.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Pale
    March 1, 2007 at 2:06 pm
    [Shane Ross] “If it was created on a PC there will be issues.”
    I have only heard of problems on PC created files if they have layers, which PICT files don’t support anyway.
  • Jason Noto
    March 5, 2007 at 3:23 pm
    It is an RGB + Alpha .pct file in its original format
    Jason
  • Jason Noto
    March 5, 2007 at 3:30 pm
    Thank you very much!
    Converting the original .pct file into a Targa document allowed me to import into FCP, as well as reverse and isolate the Alpha channel
    Jason
  • John Pale
    March 5, 2007 at 3:34 pm
    e-mail me the file.
    pale.edit
    AT
    mac.com
