Activity Forums Apple Final Cut Pro Legacy importing Panasonic P2 footage into fcp from an external hard drive
  • importing Panasonic P2 footage into fcp from an external hard drive
    Posted by Liptap on August 23, 2007 at 8:58 pm
    I have been given an external hard drive packed full of footage taken from a panasonic P2 card and have been asked to edit a feature. Problem is, in FCP I go IMPORT>Panasonic P2> select the hard drive> select the individual P2 card’s info, then I get a bunch of thumbnail clips in the import window (and I can see the image of the clacker for each take). The problem is this: When I click IMPORT I get this error message “One or more P2 clips failed to import; probable incomplete or corrupt files”. So where do go now? Any help would be great.
    Liptap replied 18 years, 10 months ago 2 Members · 2 Replies
  • Steve Covello
    August 24, 2007 at 1:05 pm
    The import process requires the .txt files in addition to the MFX files. Any import problems I have heard about has stemmed from some smarty thinking some piece of data was not necessary and deleting it. Are there any text files missing?
    steve covello
  • Liptap
    August 24, 2007 at 6:19 pm
    No, I have imported ALL the related files (the contents folder and the last clip as well). I am at a place wear if I can just make quicktime files I can at least VIEW the clips.
