Activity › Forums › Apple Final Cut Pro Legacy › importing p2 card media off firewire into final cut
  • importing p2 card media off firewire into final cut
    Posted by Brian Spitz on May 4, 2008 at 5:58 pm
    Yes. First time user with the P2 deal. I thought FCP would import the MXF files as QuickTimes but for some reason it’s not, bringing them into FCP as MXF’s. I imported the entire CONTENTS folder….any ideas?
    thanks.
    David Hueso replied 17 years ago 4 Members · 4 Replies
  • Russell Lasson
    May 5, 2008 at 1:06 am
    If you’re using FCP 6, then use the Log and Transfer window to open them.
    If you’re using FCP 5, then use the Import-Panasonic P2 window to import the files.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Brian Spitz
    May 5, 2008 at 2:01 am
    right. this mounts the p2 footage. unfortunately not everything is mounting for some reason. my friend who was logging the footage looks to have changed the names of some of the folders…i think that could be it. any idea how to remedy that?
    thanks!
  • Collin Carrothers
    May 11, 2008 at 6:10 pm
    I’m using FCP 6 and have used the log and transfer window to open and view files from am external hard drive. Now how do I now get them into my project file for editing? When I try to import I get an error message, and I tried to drag and drop into the bin or sequence but that doesn’t work either.
  • David Hueso
    September 29, 2009 at 9:29 pm
    why? my fcp is 6.0.5
    and dont show me File> import> p2
    is a driver ? o plugin?
