Activity Forums Boris FX Particle Illusion Importing only 9 picture sequence
  • Importing only 9 picture sequence
    Posted by Craig Cooper on October 3, 2007 at 9:03 am
    Hi All,
    I changed the shape of particle and am trying to use sequence of 13 pictures with similar names eg pic1, pic2 etc. But it only imports 9 of the 13. I have put them in a seperate folder. Does it depend on the particle that I’m using?
    Craig
    Alan Lorence replied 18 years, 11 months ago 3 Members · 2 Replies
  • Sockratease
    October 3, 2007 at 9:22 am
    Try renaming the lot to “pic001” to “pic013” as sometimes the transition from “pic9” to “pic10” has translation problems!
    At least in other software.
    I have never had the problem you describe in Particle Illusion, but I have seen this in other sequence-importing software.
    I’m no expert, nor am I the support staff, so I hope that helps.
    Good luck with it.
    Peace.
  • Alan Lorence
    October 3, 2007 at 11:14 am
    That’s exactly it. You need to add leading zeros to the sequence number, so all the images have the same number of digits.
    Alan.
    http://www.wondertouch.com
