Activity › Forums › Avid Media Composer › importing OMF2 from Heavyworks to ComposerAdrenaline
  • importing OMF2 from Heavyworks to ComposerAdrenaline
    Posted by Frank Feijen on May 2, 2005 at 3:39 pm
    I’m trying to import a OMF2-audiofile, created on a Heavyworks 25iPal-project – into the composer 25iPal-project. It imports the file and than says it’s NTSC that can’t be used in a 24p-project!
    Any clues on how we can get this importing to work?
    Frank Feijen replied 21 years, 5 months ago 3 Members · 3 Replies
  • Michael Phillips
    May 3, 2005 at 12:46 am
    Yikes! As with any file format, it is a matter of finding out if it is part of the export from Heavyworks causing the problem, or is it on the import side of things. Have you tried just a single clip as OMF2 to narrow it down?
  • Michael Buday
    May 3, 2005 at 1:17 am
    First of all, what “Composer” are you referring to? Mac based? PC based? Software rev. etc.
    Secondly, you mention that that you’re attempting to import a PAL Heavyworks OMF into a PAL Composer project, but you say the error message contains a reference to “24P”?
    Are you importing this into “Video” based project or a “Film” based project?
    And just for reference, most likely the problem is with the HeavyWorks OMF EXPORT, not the Avid IMPORT.
    Michael Buday
  • Frank Feijen
    May 3, 2005 at 6:23 am
    Thanks for the quick replies,
    It’s a PC-based ComposerAdrenaline 2.0.3,
    and it’s a video-project.
    I’m also assuming that the problem would be on the Heavyworks-side, but i believe that it used to work fine on older Avids, i’ll give that a try to make sure.
    The only working method so far is sending it trough digitranslator to protools and back to OMF – export in to the Avid, but then we loose all of our fades.
