Activity › Forums › Apple Final Cut Pro Legacy › Importing NTSC footage from MiniDV to FCP5
  • Importing NTSC footage from MiniDV to FCP5
    Posted by Joe Sinclair on September 10, 2008 at 3:04 pm
    Hello,
    I did a wedding video using two cameras. One was PAL and the other was NTSC.
    I have no trouble importing the PAL video.
    But when I try to Capture the NTSC tape, even though Capture window says VTR OK (and will control the tape deck), it only shows colour bars and will not import the footage (it says waiting for timecode and then says there is no footage).
    I have changed all the settings in FCP to NTSC, trashed preferences, and tried opening it all in a new project but I cannot get it to work.
    I’m sure it’s something obvious. But I have never been able to import NTSC footage. I am using a PD150 to try to import. The tape plays fine in the camera.
    Hope someone can help. The groom is getting impatient…
    Randy Lee replied 18 years ago 4 Members · 3 Replies
  • Kevin Monahan
    September 10, 2008 at 5:04 pm
    Have you tried Final Cut Pro > Easy Setup > NTSC DV?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Tom Brooks
    September 10, 2008 at 5:11 pm
    You should be able to capture using the correct easy setup as Kevin suggests. After your NTSC footage is captured you will need to convert it to PAL in order for it to work properly in the PAL timeline. Or convert the PAL to NTSC if you’re working in an NTSC timeline. You’ll need something like Nattress Standards Converter.
  • Randy Lee
    September 10, 2008 at 5:55 pm
    Will the camera or deck that you’re using play back the NTSC tape at all? Can it handle both PAL and NTSC? You might have to find a deck or camera that will play it back. Then you get to the fun part…getting the two to play well together…although as long as there isn’t any fast horizontal movement, the Nattress converter should do it for you.
