Activity Forums Apple Final Cut Pro Legacy importing MXF files into FCP
  • importing MXF files into FCP
    Posted by Gary Huggins on November 15, 2012 at 9:49 pm
    I have some Canon C300 MXF files that I need to import into FCP 6.0.6
    These files were recovered from a corrupt card, so I don’t have any of the directory files or folders, just the MXF files.
    Are there any free ways to get them into FCP? Or will I have to spring for a converter?
    Shane Ross replied 13 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    November 15, 2012 at 11:36 pm
    Your best bet is software that allows your computer and FCP to read the MXF files…Calibrated MXF Import would be what I’d recommend.
    Unsure if the MXF format the C300 records is something FCP 6 can work with. But if you can see the footage, you might see if you can import it, and if you can, then use the MEDIA MANAGER to convert this to ProRes 422.
    Shane
    Little Frog Post
