Activity › Forums › Apple Final Cut Pro Legacy › Importing MXF files into FCP 6.0
Lala 1a1a
July 20, 2010 at 12:11 amHi,
I have never worked with mxf files but have edited videos on FCP. You have suggested that we should do log and transfer and convert the files to qt. Could you please give a step of direction? I have captured dv tapes before never clicked on the log and transfer plugin. All my mxf files are saved on a portable hard drive. Thank you in advance.
Shane Ross
July 20, 2010 at 12:15 amMXF from P2? I hope you have the full cards backed up. And yeah, I have a tutorial:
https://library.creativecow.net/articles/ross_shane/p2fcp6.php
Shane
Read my blog, Little Frog in High Def -
Terry Mccaul
December 6, 2010 at 4:01 pmHi jeremy, i’m having the exact same issue. Can I ask what software you used to work around it?
Many thanks
Jeremy Garchow
December 6, 2010 at 6:13 pm[terry mccaul] “Hi jeremy, i’m having the exact same issue. Can I ask what software you used to work around it?”
Hi, Terry. I use (and highly recommend) MXF4mac QT Import.
https://mxf4mac.com/index.php/quicktime-plug-ins.html
Jeremy
Terry Mccaul
December 7, 2010 at 6:53 pmMany thanks jeremy!
One more question – does anyone happen to know the directory structure for mxf files? I ahve the plug-in for FCP and now need the final piece of the puzzle, that i hope will work…
Yes I downloaded the .xf files from my CF cards without the card structure. Lesson learned but now need a solution!
Thanks all
Shane Ross
December 7, 2010 at 7:17 pmI use Calibrated and MXF4Mac…I think I am leaning towards Calibrated for the quick stuff.
Sorry, if you lack the card structure, you can’t just rebuild it and things will work. The other folders in that card structure contain files that relate to the MXF files, like AUDIO and CLIP…clip being the metadata. If you lack those files, FCP cannot import the files via Log and Transfer. Rebuilding will not help now.
Shane
Terry Mccaul
December 7, 2010 at 7:37 pmThanks for the fast reply Shane.
Ah, I see. So the ONE & ONLY way to now edit my files in FCP is getting this software (not a huge problem)? What about making them prores files in Avid, then compressing, could that work? Without the full structure?
My files read – CLIPS000/AA0000/AA000.CIF
AA000.XML
AA000001.MXF
AA000001.SIF -
Shane Ross
December 7, 2010 at 7:44 pm[terry mccaul] “So the ONE & ONLY way to now edit my files in FCP is getting this software (not a huge problem)? “
Correct. Calibrated…MXF4Mac…Raylight. Only ways.
[terry mccaul] “What about making them prores files in Avid, then compressing, could that work?”
Avid doesn’t make them ProRes. ProRes is an APPLE thing. Avid will import and work with the files natively, as that is the file format it currently uses. But then you’d have to get all the clips out of Avid to FCP…meaning you’d have to export them as Avid QT files…and download the Avid codecs so that FCP could see them. Or import them into Avid, string them all out on a timeline, and get Automatic Duck to convert the sequence from Avid to FCP.
It would be best to just get the third party options…
Shane
Terry Mccaul
December 8, 2010 at 3:42 pmHi Randy, can I ask what the $35 piece of software was you used?
