Activity Forums Apple Final Cut Pro Legacy Importing MXF files into FCP 6.0
  • Jeremy Garchow
    February 10, 2010 at 10:08 pm
    [Shane Ross] “Well…you are trying to fix a mistake…a pretty big one. Not saving the entire card structure.”
    Oh no, no. That’s freee! Don’t you get it? Why would you pay for something that will help clear up a mistake? I bet whoever shot it got their day rate, even though they almost took down the shoot.
    But $500 for software that works? Man, that is way out of line.
    It should be freeeeeeeeeeeee!
  • Randy Hopkins
    February 11, 2010 at 12:05 am
    1. The problem is not $500 for software that works, it’s $500 for trivial importing functionality that should already be included in the grossly overpriced FCP.
    2. The camera op assumed a level of competency software side that apparently doesn’t exist for FCP users at this point.
    3. We’ve decided to get around that incompetency and just rewrap everything as MOV with a $35 piece of software. Another successful FCP circumventing (sad, sad, sad).
    Thanks for the help though, guys! Really couldn’t have done it without your snide remarks and vague, misguided direction!
  • Jeremy Garchow
    February 11, 2010 at 12:07 am
    [Randy Hopkins]
    Thanks for the help though, guys! Really couldn’t have done it without your snide remarks and vague, misguided direction!”
    Not a problem. Enjoy!
    Jeremy
  • Shane Ross
    February 11, 2010 at 12:17 am
    [Randy Hopkins] “t’s $500 for trivial importing functionality that should already be included in the grossly overpriced FCP. “
    GROSSLY OVERPRICED! Man, where are you coming from? Where were you when an Avid cost $65,000? OVERPRICED? Avid costs $2295 and is a deal. Premiere costs, what? $1000? FCS too? What are you basing THAT math on? Sony Vegas? iMovie?
    FCP is QT based…always has been. If you don’t like it…if you want that “trivial import functionality,” then you can always go to Premiere. Don’t get FCP then bitch about what it can’t do. There are tons of editing apps out there to choose from.
    [Randy Hopkins] “2. The camera op assumed a level of competency software side that apparently doesn’t exist for FCP users at this point. “
    No, the camera op assumed that what he was doing was right and proper…and they were just plain WRONG. Always archive the full card. This is the standard practice for ALL tapeless formats. If they only backed up what they did because it works for ONE NLE, but not all, then they made a mistake. Human error…pure and simple. They assumed wrong. Never assume. Back up fully. Now you see what happens when you assume.
    [Randy Hopkins] “3. We’ve decided to get around that incompetency and just rewrap everything as MOV with a $35 piece of software. Another successful FCP circumventing (sad, sad, sad). “
    Good. Glad it worked. If you dislike FCP so much, why are you using it?
    [Randy Hopkins] “Really couldn’t have done it without your snide remarks and vague, misguided direction! “
    Welcome…glad to give you more for all the attitude you have given this thread. You give attitude, you get attitude. Sorry you didn’t like our answers. Glad you found a solution on your own.
    Good luck.
    Shane
  • Arnie Schlissel
    February 11, 2010 at 12:45 am
    [Randy Hopkins] “$500+ software isn’t an option in this case, though I appreciate the suggestion. “
    So, what you’re telling me is that your project isn’t really important enough to be worth $500.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Michael Sacci
    February 11, 2010 at 1:35 am
    Wow, sure is a lot of haten’ going around the cow.
    From now on, all answers should start with… FCP totally sucks and it get it to do what it should do right out of the box try…
    $1000 buck for software that you can edit and CC uncompressed HD footage with, the nerve.
  • Rafael Amador
    February 11, 2010 at 1:40 am
    With the last version of Clip Browser you can read the MFX on your Mac.
    rafael
    http://www.nagavideo.com
  • Alex Elkins
    February 11, 2010 at 4:29 pm
    Hi Randy,
    I believe Clip Browser (free from Sony) will allow you to re-create the correct file structure onto an SxS card which you can then Log & Transfer into FCP without problems. I did a similar thing to this recently as some data had become corrupted or was missing even though the actual video files were clearly there. I’d give that a try before parting with any cash.
    The fact that FCP doesn’t read these files natively isn’t really an Apple shortcoming – Sony does it’s best to make it difficult to use the files in anything outside of Sony Vegas. Typical Sony, and typical of third parties to find ways around it and then charge good money for the technology. I understand your frustration though, it can seem like the world is against you when things just don’t work properly.
    The simple solution, of course, is to repeatedly punch the person responsible for erasing the original file structure.
    All the best,
    Alex Elkins
    Salad Daze Films – Freshly Tossed
    Read my blog!
  • Mark Santa-maria
    March 16, 2010 at 2:34 am
    Randy, I didn’t see where you mentioned if the original BPAV files were already gone and could not be used to just import directly into FCP using the log and capture or the stand alone sony app xdcam transfer.
    If you no longer have access to the BPAVS, then what was the 35 dollar solution you found. Was it lossless and quick? Let us/me know –
    Mark
  • Phaedra Bell
    March 30, 2010 at 5:39 pm
    I have been given footage on an EXT HD in XML/MXF format and when I try to import it into FCP it says I need to choose a translation document.
    I have never done this before and do not understand the command.
    Can anyone please help on explaning how I get the files to work in FCP.
    Many thanks
Page 2 of 4
