Activity Forums Creative Community Conversations Importing .MXF file problem
  • Importing .MXF file problem
    Posted by Gareth Chan on June 18, 2015 at 7:03 pm
    I updated my final cut to 10.2, updated my OSX with Pro format support, downloaded the Sony plugin for FCPX but how come in final cut when I try to import my .MXF file shot on Sony F7S it only has sound and no video??? I can’t edit my .mxf files please help!,
    Jeremy Garchow replied 11 years, 3 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    June 19, 2015 at 2:50 pm
    As far as I know, fs7 media should be xavc which fcpx handles just fine.
    How are you importing the media? Drag and drop or import window?
  • John Rofrano
    June 20, 2015 at 1:59 pm
    You said that you downloaded a Sony plug-in but FCP X can now import MXF natively. Could it be that the Sony plug-in is actually preventing FCP X from using it’s native capabilities?
    I recently got a warning when FX Factory applied an update that I had an old XDCAM plug-in that was no longer needed and it recommended that I delete it so I did. Perhaps you are in a similar situation with FCP X recently adding MXF support.
    Try removing the Sony plug-in.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeremy Garchow
    June 20, 2015 at 3:14 pm
    I don’t think this matters. The Apple plugin seems to be the exact same Sony plugin. Both of these rewrap the footage to .mov (a waste in my opinion)
    I drag and drop XAVC material to use the native MXF and bypass the import window.
