Activity Forums Adobe After Effects Importing multiple images into AE with the photoshop layers remembered??
  • Importing multiple images into AE with the photoshop layers remembered??
    Posted by Alex Thurston on March 9, 2011 at 1:23 am
    So I am currently making an animation and importing charcoal drawings Ive done into after effects in multiple sequence which is fine. But the problem I am having is that the photoshop layers aren’t remember like if you import a single picture edited in photoshop into after effects. And so when I cut round each picture in photoshop and then import them all together into after effects the parts of transparency that are normally remembered aren’t. Which means i get all the rest of the picture that I dont need.
    I essentially need my character cut away from the rest of the picture that I dont need. So that you can see the backgrounds etc i have done in AE.
    If anyone could help/suggest some tips I would be more than grateful!
    thanks
    Brian Charles replied 15 years, 6 months ago 2 Members · 1 Reply
  • Brian Charles
    March 9, 2011 at 2:38 am
    Are you importing them as a Composition or as flattened layers?
    Try Import as Composition > Retain Layer Size (CS5)
    OR CS4 <
    Import as Composition >Cropped Layers
