Activity Forums Adobe Premiere Pro importing multiple files
  • importing multiple files
    Posted by Bodybuildingbs on December 1, 2010 at 12:50 am
    Hello
    I have a file folder full of multiple tiffs that I want to import into adobe premiere pro in order to make an animation.
    I click on import then find the folder. Next I select the first tiff and click numbered stills and then click open.
    Premiere Pro only imports the first still.
    The only problem I can find is that they are supposed to be number 00 01 02 and mine are animated in Maya and are numbered 1,2 3.
    Is there a workaround for this problem.
    Thank you
    Jeff Pulera replied 15 years, 9 months ago 3 Members · 2 Replies
  • Andrew Devis
    December 2, 2010 at 6:39 pm
    You could try this, go to your preferences and change the default for image input to 1 frame. Then after you have done this import the folder with all the stills in – make sure they are in the correct order and select them with the shift key first to last and then automate them to the sequence. It should work but no promises.
    Hope this helps
    Andrew
    … because it’s all about stories …
  • Jeff Pulera
    December 3, 2010 at 10:33 pm
    Maybe you just need to rename the first 9 clips until they hit double digits? Otherwise, download the free IrFanView image software, does a lot of neat stuff including batch rename so you can name the files properly
    Jeff Pulera
    Safe Harbor
