Activity › Forums › Adobe After Effects › Importing Mpeg2
  • Importing Mpeg2
    Posted by Jake74 on September 13, 2007 at 12:47 am
    Hello,
    I’m trying to import some video footage shot with a Panasonic SDR-H18 camcorder that is in mpeg2 format. I’ve tried to import directly into AE7 and I receive the “cannot open movie because it has no duration” error. I have purchased the Mpeg2 player for Quicktime Pro which said could convert the mpeg2 video into other formats. When I converted the mpeg2 into a .mov file, I still received the same error on import. I usually have no problem importing .mov files. Any ideas? Should I be converting mpeg2 files to some other format?
    Steve Roberts replied 19 years ago 3 Members · 4 Replies
  • Steve Roberts
    September 13, 2007 at 12:01 pm
    I thought the QT MPEG2 plug just allowed you to view MPEG2. Hm.
    You should convert the MPEG2 movie to a QT MOV codec such as Photo-JPEG or Animation.
    I think I used “MPEG Streamclip” the last time I had to do that.
  • Darby Edelen
    September 13, 2007 at 3:30 pm
    [Jake74] “I usually have no problem importing .mov files.”
    .mov is a container format. Like .avi it does not define a codec, but contains the video information in an encoded form (any codec supported by QT can work in an .mov) as well as other metadata.
    You should try transcoding your video to something with only intraframe compression (I frames) like Photo JPEG at max quality.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Darby Edelen
    September 13, 2007 at 3:39 pm
    [Steve Roberts] “I thought the QT MPEG2 plug just allowed you to view MPEG2. Hm.”
    I believe you are correct sir, although I am able to transcode MPEG-2 files straight out of QT Player. I have QT Pro and Final Cut Studio though, which may install some extra whizzy stuff.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Steve Roberts
    September 13, 2007 at 3:44 pm
    Ah. Yes.
    There is no use in converting the MPEG-2 to a MOV if the MOV still uses MPEG-2 as its codec.
    As Darby wrote.
