Activity › Forums › Adobe Premiere Pro › Importing mov files into premiere pro
  • Importing mov files into premiere pro
    Posted by Kevin Gonzales on September 4, 2009 at 2:49 am
    OK, I’ve got a Panasonic HPX170. I shot some footage (shot in DVCPRO 100 720p 30) and converted the MXF file to a .MOV file via FCP. I put the .mov files on a portable hard drive and gave them to a production house that uses Premiere PRO cs3 on a mac. They cannot view the .mov files nor will then import into Pre Pro. Then can see that there is a .mov file on the hard drive put can’t play it. Even with QT Pro, no dice.
    When they try to import into Pre Pro it says they are missing a codec. Any suggestions as to how to get them into Premiere?
    Eric Jurgenson replied 17 years ago 2 Members · 1 Reply
  • Eric Jurgenson
    September 4, 2009 at 3:13 pm
    The DVCPRO100 .mov codec, like the HDV .mov codec, is exclusive to FCP, and not available with Quicktime player unless FCP is installed. You need something like the Raylight plug-in, which will enable the DVCPRO100 .mov codec without FCP installed.
    Note that native DVCPRO100 and HDV will work in Premiere without the plug-in.
