Activity Forums Adobe After Effects Importing Motion projects into AE
  • Importing Motion projects into AE
    Posted by Craig Wall on September 29, 2007 at 8:47 pm
    I watched a tutorial on how to import a Motion project into an AE project. Cool.
    Link here:
    https://www.seminars.apple.com/seminarsonline/motionae/apple/index1.html
    (the importing is done starting at about the 15 minute point of the tutorial)
    Only catch is that when I follow these directions I get an error in AE:
    … cannot be imported – files of type “mofo” are not supported.
    Obviously I can still render a quicktime .mov out of Motion and pull that in. That’s not the point–I want to integrate live projects.
    Anyone have success when using the latest Motion with the latest AE?
    Jeff Patrick replied 18 years, 7 months ago 5 Members · 5 Replies
  • Adolfo Rozenfeld
    September 29, 2007 at 9:42 pm
    You just need to add the .MOV extension to the Motion project files.
  • David Bogie
    October 1, 2007 at 1:52 pm
    .MOV or .MOTN?
    bogiesan
  • Adolfo Rozenfeld
    October 1, 2007 at 2:23 pm
    .MOV, again.
    Motion’s Quicktime component is what allows other applications, like AE or the QT player itself, to import Motion project files as movies. When you rename or add the .MOV extension, they just take it as a a QT file.
  • Mark
    November 7, 2007 at 12:21 am
    I’m having problems doing this, does it matter what version of motion I have?
  • Jeff Patrick
    January 9, 2008 at 3:42 am
    https://www.apple.com/pro/techniques/motionaftereffects/
    I keep getting errors by trying this, using AE CS3 and Motion 3 on Intel Mac. Any help? Changing the ext. to .mov just turns it into a QT file only. Apple says you can import a Motion Project, then Edit Original, then make changes in Motion that will be updated in AE.
