Activity Forums Apple Final Cut Pro Importing media question
  • Importing media question
    Posted by Don Scioli on July 27, 2017 at 10:18 pm
    Hi, with the 10.3 upgrade, I noticed that when importing footage from my Canon XF300, say a clip is labeled AA4820,
    there will be an identical clip labeled AA48201, basically adding a copy of the same clip with an extra numerical.
    I’ve just been deleting them , but can someone explain what is happening.
    thanks in advance.
    Brett Sherman replied 9 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    July 27, 2017 at 10:41 pm
    Are you sure it’s not part 2 of a long clip?
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Don Scioli
    July 27, 2017 at 10:56 pm
    No, it’s an exact dupe, yet sometimes it’s broken up into smaller clips with ascending numbers on each one. The “good” clips do not have the extra end number.
  • Noah Kadner
    July 28, 2017 at 12:03 am
  • Don Scioli
    July 28, 2017 at 12:10 am
    I’m using a Raid drive. 2 drives in there, Mac OS Extended (Journaled). Never had this problem until 10.3 the previous versions of FCPX were fine with this drive
  • Noah Kadner
    July 28, 2017 at 12:15 am
    I’d suggest reinstalling the latest plugins for your camera.
    Noah
  • Don Scioli
    July 28, 2017 at 12:33 am
    Many thanks, I probably had an older version. Will try tomorrow.
    Don
  • Brett Sherman
    July 31, 2017 at 1:44 am
    This is how Canon XF names it’s files on the card when it records. It sticks a 1 on the end for the first clip, if it’s a long clip, then it splits it into multiple files 2, 3 and so on. When you use the Canon XF FCP X plug-in it eliminates that last number and combines all clips together into a single .mov. If you import the .mxf files without rewrapping that’s exactly how it will come in.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
