Activity Forums Avid Media Composer Importing media into MC 6.5
  • Importing media into MC 6.5
    Posted by Victor Vazquez on June 23, 2013 at 1:44 am
    Hello,
    I am very new to using Avid (I’m using Media Composer 6.5) and I’m not able to import any media into my bins.
    When I try to import, the message “There are no media drives available. You will only be able to import shot logs.” appears. Then when I go to the Select files to Import dialog and select a media file to import, either nothing happens or the message “You cannot import this file into a bin. See the documentation for information about transferring media files.” appears.
    Why am I not able to import these media files into the bins? And how can I go about to import them into the bins?
    Victor Vazquez
    Victor Vazquez replied 13 years, 3 months ago 2 Members · 8 Replies
  • 8 Replies
  • Michael Phillips
    June 23, 2013 at 3:29 am
    Make sure your drive have read/write permissions.
    Michael
  • Victor Vazquez
    June 23, 2013 at 4:07 pm
    Hi Michael,
    When I open the program the message “No media can be written to any mounted drive. Please check write permissions.” appears. I’m wondering how I can change these settings. When I click Get Info on my drives, it appears that I already have read and write privileges.
    Victor
  • Michael Phillips
    June 23, 2013 at 4:15 pm
    If OSX, I know it resets read/write after a “check permission” is done from disk utility. I would start the process again – in disk utility, check permissions. Once complete, get info on drive and set read/write for everyone.
    Michael
  • Victor Vazquez
    June 23, 2013 at 5:36 pm
    I verified and repaired disk permissions then added read and write privileges for everyone, yet the program still cannot import media.
    Victor
  • Michael Phillips
    June 23, 2013 at 10:57 pm
    Hmmm… This happened to me once, but I can’t remember exactly why it started working again. Check media creation settings and make sure none of the drive filtering is on.
    Michael
  • Victor Vazquez
    June 23, 2013 at 11:49 pm
    I have all of the Drive Filtering and Indexing setting unchecked.
    Victor
  • Michael Phillips
    June 24, 2013 at 12:56 am
    I’m running out of ideas… perhaps try uninstalling and reinstalling the software?
    Michael
  • Victor Vazquez
    June 24, 2013 at 2:38 am
    The problem was that the program wasn’t recognizing my Mac Hard Drive as a drive. Now I’m using an external HD and AVID MC is up and running 🙂
    Victor
