Activity Forums Apple Motion Importing lower3rd from Motion into Final Cut
  • Importing lower3rd from Motion into Final Cut
    Posted by Elsvandeveire on August 15, 2007 at 9:22 am
    Hi, does anyone know how I should import lower 3rds from Motion into FCPro in a transparant way, without the black background ? I know about alpha channels, but somehow I still manage to have a black background when importing in Final Cut… Tx a lot ! Els
    Jemschofield replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jemschofield
    August 15, 2007 at 1:26 pm
    In Motion, press command-J to bring up your project properties. Make sure your background id transparent.
    As long as you are importing a native .motn file into FCP, that should be all you need to do.
    If you are rendering (export), make sure that you are exporting the project with an Alpha channel.
    Hope that helps.
    jem schofield
    producer/creative director/author
    apple master trainer
    Buttons Productions
