Activity Forums Adobe Premiere Pro importing into premiere pro
  • importing into premiere pro
    Posted by Bodybuildingbs on June 5, 2005 at 6:24 pm
    I have a fairly complex project in premiere 6.5 that I cannot import into premiere pro 1.5 as when I try it states that an unknown error has occurred. I was thinking of breaking the 6.5 project down into say 10 minutes segments and see if I could import each into premiere pro to see where the problem is as earlier versions of this project will import but it would take a lot of foley work to bring it up to speed.
    So is it possible to import several projects into premiere pro and how would I attach them..I mean you have one project on the timeline and you want to add another right behind it..
    thanks
    David J replied 21 years, 3 months ago 2 Members · 1 Reply
  • David J
    June 5, 2005 at 9:17 pm
    Projects imported into Premiere Pro convert into separate sequences, which can then be manipulated as an entity like any other sequence, or you can delve inside and adjust the detail.
