Activity Forums Adobe After Effects importing in Element 3d v2 from cinema 4d a cloner object with animation
  • importing in Element 3d v2 from cinema 4d a cloner object with animation
    Posted by Christoph Grigoletti on March 30, 2015 at 10:16 pm
    Hi to everyone!
    I’m new to this forum.
    Has anyone of you a solution with one thing that drives me mad.
    I have a cloner object with a big cube and another cloner object as a child of it.
    I want to achieve the effect that some little objects are on one surface of the big cubes and so when i rotate the cubes they rotate with it.
    I want to import this setup to element 3d v2.
    Thank’s in advance to everyone
    I attach example of what i would like to achieve
    Thank’s much in advance if someone of you has a solution
    Jason Jantzen replied 11 years, 5 months ago 2 Members · 3 Replies
  • Jason Jantzen
    March 31, 2015 at 7:57 pm
    Two ways to get around this.
    1) Convert your C4D cloner object to mesh. You may have to bake your keyframes if you have any effectors like Delay or something.
    2) Export an OBJ sequence from C4D and import that into Element. I use the Riptide Pro plugin for that.
    Jason Jantzen
    vimeo.com/jasonj
  • Christoph Grigoletti
    March 31, 2015 at 8:38 pm
    Thank’s much!
    You are absolutely right.
    Yes usually i convert my cloner to a mesh and move the converted mesh under a fracture object to achieve the same setup with effectors.
    In this case it’s not possible because i have a cloner that is a child of another cloner so it’s not possible to move it to a fracture object.
    I tried to bake the effectors with the cloner millions of times and it never worked.
    But this time it worked ,strangely for me.
    I did almost the same like other times but this time it worked.
    I used nitrobake.
    Crazy.
    Thank’smfor your repsonse
  • Jason Jantzen
    March 31, 2015 at 9:25 pm
    NitroMan is the shiznit. I’ll have to check that one out. I’m glad it worked. Getting those keyframes to bake can be a pain in the butt sometimes, I agree.
    Jason Jantzen
    vimeo.com/jasonj
