Importing Images To Fit Full Wireframe For Time Lapse in FCP7
I am working on a Final Cut Pro project that includes 2 time lapses. I’ve decided to try importing the images directly into FCP as opposed to a single Quicktime video in order to preserve greater image quality, BUT I do not want to resize every images to fill the wireframe as I have over 1000 images. Is there a setting that will automatically size the images to fill the entire wire frame so I don’t see black bars on either side of the still photo? OR is there a way that I should save my images before importing them that will make them the size of the complete wire frame? I tried importing an image with the width of 1920pixels, but it still came out with the black bars on either side.
My sequence is set at 1920×1080 HDTV 1080i (16:9), Pixel Aspect Ratio: Square. I did not choose these settings specifically, as I think that program chose whatever worked best with the 7D footage that I’m using.
Any information would be super helpful. Thank you in advance!
