Activity Forums Apple Final Cut Pro Legacy importing images from photoshop into FCP and losing quality
  • importing images from photoshop into FCP and losing quality
    Posted by Kate Perkins on June 9, 2009 at 9:27 pm
    Hi there,
    I am trying to overlay some images created in photoshop over footage in FCP (cutesy text for a home movie.) The source footage is 30fps (not 29.97), and the sequence is also at 30fps. The still images, however, are 29.97. When I export, the video looks beautiful but the text looks strange – pixelated around the edges, like there is some sort of interlacing problem? I’m sorry I do not know the correct terminology for this. I have tried changing the frame rate for imported images, but in all of the settings and preferences I can not find how to do this. I have tried to change the settings for just those images but can not find how to change them. Can anyone help?
    Many thanks,
    Kate
    Rafael Amador replied 17 years, 3 months ago 2 Members · 4 Replies
  • Kate Perkins
    June 9, 2009 at 9:46 pm
    Quick update: I tried importing one psd file into After Effects and exporting as a quick time at 30fps, but this looks exactly the same as the still images once imported into final cut. Hmm.
  • Rafael Amador
    June 10, 2009 at 10:59 am
    Hi Kate,
    What kind of footage are you editing?
    Which codec have you set for your sequence?
    [Kate Perkins] “The still images, however, are 29.97. “
    Still images have no time-base. No “fps”. They will be played with the time-base of your sequence.
    rafael
    http://www.nagavideo.com
  • Kate Perkins
    June 10, 2009 at 3:43 pm
    The footage is from my digital camera, a Canon SD 900 IS. It’s H.264 at 30fps. The sequence is “DV/DVC PRO – NTSC”. The item properties box for the still images have 29.97 as the video rate, but the clips are at 30. This is the only inconsistency I can find to explain the degradation of those still clips.
    Thanks Rafael!
    -Kate
  • Rafael Amador
    June 10, 2009 at 4:07 pm
    Hi Kate,
    The problem are not the stills, but the sequence codec.
    Change it to ProRess and set the Field order of your sequence as NONE.
    Render a little and have a look.
    Rafael
