Activity Forums Adobe Premiere Pro importing images and vector graphics
  • importing images and vector graphics
    Posted by Neil Bradley on May 21, 2007 at 5:23 am
    I was experimenting with importing high resolution photographs into a project created in Premier Pro with varying results and wondered what everyone else does?
    Id like to display photographs as part of a movie project and need the very best results as the images are an important part of the project. I import the images into Photoshop so can apply whatever setting to the file size or resolution. Then when I import the image into Premier Pro what fields setting give the best result?
    If I created typography in Photoshop and keep it as a vector graphic what resolution setting gives the best results? Also what field setting gives the type the best results when imported into Premier?
    Look forward to your advice…
    Neil Bradley replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
